Improvements to Onshape - June 15th, 2018
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
In this latest update we have made improvements across multiple aspects of Onshape. A lot of these updates have been driven by the improvement requests sent in by you, our customers. If you have improvement requests, please submit your ideas here. Let us know what you think.
CAD IMPROVEMENTS
WORKING IN SHEET METAL FLAT PATTERN
You can now create sketches and features in the sheet metal flat pattern. This allows users to simultaneously design their sheet metal in both the flat and folded state.INCLUDE VISIBLE SKETCHES IN FLAT PATTERN EXPORT
Another improvement to sheet metal with this update is the option to include visible sketches when exporting a sheet metal flat pattern as a DXF or DWG. This can be useful if you need etching lines in your flat pattern for Production.
OVERRIDE TESSELLATION SETTINGS
You can now control the tessellation quality of parts in a Part Studio for when you are performing small, detailed designs or visually checking tolerances and fit. This part property is configurable so you can change part configurations in assemblies to low resolution when working and high resolution when making images.MATING HUD TOOLBAR
Mating workflow speed is now improved with a HUD toolbar that appears next to your cursor to quickly change mate types and orientation. This also allows for rapidly chaining together the creation of multiple mates in a row.PROCESS MULTIPLE DOCUMENT TABS
The tab manager now has expanded capabilities for sorting Document tabs and processing multiple tabs at the same time. This can be useful when reorganizing projects.API EXPLORER IMPROVEMENTS
Developers will now see an updated API Explorer environment with this release. The UI has been updated and the performance of the explorer has been improved for loading time and responses. API keys are now required for all calls through the API Explorer.PROFESSIONAL FEATURES
UPDATE DRAWING PROPERTIES ON RELEASE
Drawings that have been approved in a release workflow now show 'Drawing approved by' and 'Drawing approved date' properties in a drawing note.ABILITY TO HAVE TEAMS AS APPROVERS
You can now select teams as approvers in the release candidate workflow. When selecting a team as an approver, the release occurs when any one member of the team approves it.
AUTOMATICALLY OBSOLETE PREVIOUS REVISION
The release workflow is more streamline with the company setting to automatically obsolete a previous revision when a new release is approved for an object.ENTERPRISE FEATURES
INTELLIGENT TEAM SELECTION IN PROJECTS AND SHARING DIALOGS
In the Document sharing dialog and Onshape Enterprise Project dialog, Onshape will now suggest teams to select as you type in their names just like when selecting individuals.
6
Thanks, Team!
This solved my improvement request from October 2017 (which was declined at that time)
Your document isn't upgraded yet. It will work when the upgrade is done.
The implementation here is brilliant, I love how it just pushes across to the model, I am really excited to see this feature come in.
Thank you!!
Sheet metal flat patterns - genius.
Cheers
We never 'decline' an improvement request
All requests from all users are tallied and all enhancement requests from Pro users are tracked by user.
If in aggregate, a request gets a lot of hits/votes, it moves up.
If we spot a pattern amongst Pro users, it moves up.
Sometimes there are prerequisites that we know we have to do first.
Just to tease you - of the top two enhancements in our system today, one is blocked by a significant behind-the-scenes piece of work that is being worked on now and the other (which will take multiple sprints), is also being actively worked on. Why am telling you this - because it's important to always submit requests (especially as a Pro user). Tell us if it's a 'need' (i cant do this any other way), a 'want' (there is a work around, but i really want this as its would be so much better), or a 'nice to have'.
We are glad that you like this release - a lot of people worked hard and there are always late-nights to get these to you every 3 weeks.
Please tell your friends at other companies as well as your customers and suppliers about Onshape !!!
Looks really good and fixed the bug I reported a long time ago (d references any document, not just the current one).
I love the sheet metal improvements... but I miss some improments in Drawings
Why 'approved by' and 'approved date' properties are only for Drawings?
Some companies also will want to set the approved date and approved by for their Parts, Assemblies, and Part Studios
From my understanding this is a new use of the metadata, not an introduction of the feature. Parts, Assemblies and Drawings can all be released, and the releases will record who and when approved it. This update is so that this data (who and when) can now appear and be updated on a drawing when it is released, without having to manually put it in before hand.
First remarks:
- Is there no origin in flat sheet metal view?
- Fullscreen mode for flat editing?
Re an origin - because the layout of the flat is entirely dependent on which edges are open and which are bends, it would not be a good idea to dimension to an origin as the faces could change position relative to it.
Yes, there is no origin in the sheet metal flat view. Since the sheet metal flat patterns can move around in that area (if additional parts are created by splitting parts, or joined together with a tab) the global coordinate system actually ends up being less useful than you would think. References should be made to geometry of the part you are sketching on.
There is no direct fullscreen for the sheet metal flat view, but you can grab the dividers and slide them around to make the page look closer to what you want:
Thanks for the replies and clarification. I now understand about the origin. I will change my modelling approach with this in mind.
I was doing the exact thing Jake shows in the screenshot. But since my sketch on the flat is like my master sketch with lots of stuff on it I would like to take advantage of my whole screen, and not keep on wasting time dragging dividers back and forth all the time, experimenting with stuff the master sketch in the flat.
Going through and setting up all of my mates in a particular assembly/subassembly first. I didn't think the toolbar would be much faster than 'Shift+enter' but while recording the what's new video I was proven wrong.
After all the mates are complete, go back and double-click mates to edit and adjust the positioning and offsets. The mouse travel is reduced from the mates list and mate dialog. Now, I understand that based on the assembly, this is not always an ideal workflow.
Twitter: @bradleysauln
I'd like to understand your sheet metal workflow better. Could you please share a screen shot of an a sample sketch/completed part?
