Improvements to Onshape - June 15th, 2018
bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
edited June 2018 in New in Onshape
In this latest update we have made improvements across multiple aspects of Onshape. A lot of these updates have been driven by the improvement requests sent in by you, our customers. If you have improvement requests, please submit your ideas here. Let us know what you think.
CAD IMPROVEMENTS
WORKING IN SHEET METAL FLAT PATTERN
You can now create sketches and features in the sheet metal flat pattern. This allows users to simultaneously design their sheet metal in both the flat and folded state.
https://onshape.wistia.com/medias/qw8qo0xyuw
INCLUDE VISIBLE SKETCHES IN FLAT PATTERN EXPORT
Another improvement to sheet metal with this update is the option to include visible sketches when exporting a sheet metal flat pattern as a DXF or DWG. This can be useful if you need etching lines in your flat pattern for Production.
OVERRIDE TESSELLATION SETTINGS
You can now control the tessellation quality of parts in a Part Studio for when you are performing small, detailed designs or visually checking tolerances and fit. This part property is configurable so you can change part configurations in assemblies to low resolution when working and high resolution when making images.
https://onshape.wistia.com/medias/v0nyyuye2r
MATING HUD TOOLBAR
Mating workflow speed is now improved with a HUD toolbar that appears next to your cursor to quickly change mate types and orientation. This also allows for rapidly chaining together the creation of multiple mates in a row.
https://onshape.wistia.com/medias/4f687ijsrm
PROCESS MULTIPLE DOCUMENT TABS
The tab manager now has expanded capabilities for sorting Document tabs and processing multiple tabs at the same time. This can be useful when reorganizing projects.
https://onshape.wistia.com/medias/8lc1k0np1k
API EXPLORER IMPROVEMENTS
Developers will now see an updated API Explorer environment with this release. The UI has been updated and the performance of the explorer has been improved for loading time and responses. API keys are now required for all calls through the API Explorer.
PROFESSIONAL FEATURES
UPDATE DRAWING PROPERTIES ON RELEASE
Drawings that have been approved in a release workflow now show 'Drawing approved by' and 'Drawing approved date' properties in a drawing note.
https://onshape.wistia.com/medias/04q9vionxw
ABILITY TO HAVE TEAMS AS APPROVERS
You can now select teams as approvers in the release candidate workflow. When selecting a team as an approver, the release occurs when any one member of the team approves it.
AUTOMATICALLY OBSOLETE PREVIOUS REVISION
The release workflow is more streamline with the company setting to automatically obsolete a previous revision when a new release is approved for an object.
https://onshape.wistia.com/medias/0bxyl3gj6f
ENTERPRISE FEATURES
INTELLIGENT TEAM SELECTION IN PROJECTS AND SHARING DIALOGS
In the Document sharing dialog and Onshape Enterprise Project dialog, Onshape will now suggest teams to select as you type in their names just like when selecting individuals.
Twitter: @bradleysauln
«1
    Awesome, cutting the flat pattern is perfect, just what I have been waiting for.  Also off to update my Title Blocks to include the approved by and approved by date.
    Thanks, Team!
    terry_pipkinterry_pipkin Member Posts: 48 PRO
    Nice improvements keep the sheet metal upgrades coming.
    jammie_logan871jammie_logan871 Member Posts: 1
    thanks for adding the lines in the sheet metal as our company uses shear bending to form a bend and corner relief it was hard to show it thanks for listening.
    I have worked out how to create the sketch on the flat pattern but can not get it to select to do an extrude remove. Am I missing something?
    sebastian_glanznersebastian_glanzner Member, Developers Posts: 400 PRO
    Thanks for including the option to export the flat pattern without center bend lines!
    This solved my improvement request from October 2017 (which was declined at that time)  :D
    Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 210
    @brucebartlett
    Your document isn't upgraded yet. It will work when the upgrade is done.  :)
    Support & QA
    edited June 2018
    Jason_S said:
    @brucebartlett
    Thanks, yes it works in the brand new document. Sorry, it was kind of throwing me that the sketch worked but the extrude didn't work.
    The implementation here is brilliant, I love how it just pushes across to the model, I am really excited to see this feature come in.
    Very nice, thanks folks.
    Cache_River_MillCache_River_Mill Member Posts: 225 PRO
    edited June 2018
    Tessellation settings... This is perfect!
    Thank you!!
    Andrew_Enslow_3DSAndrew_Enslow_3DS Member Posts: 40 ✭✭✭
    Thanks! I usually pick my top 3, but I can't choose between all of these streamlining updates!
    SledDriverSledDriver Member Posts: 116 ✭✭✭
    Tessellation - been waiting a while for this. Nice implementation. Thanks so much.
    Sheet metal flat patterns - genius.
    Cheers
    bruce_williamsbruce_williams Member, Developers Posts: 842 PRO
    nice bunch of improvements!  I just needed sketch on flat pattern and been longing for multi-tab management.  Outstanding!
    www.accuratepattern.com
    billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,014 PRO
    Thumbs up for the API update.
    Looks really good and fixed the bug I reported a long time ago (d references any document, not just the current one).
    derek_wardderek_ward Member Posts: 63 EDU
    Awesome updates per usual.
    emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 859 ✭✭✭✭✭
    Awesome update!!!
    I love the sheet metal improvements... but I miss some improments in Drawings
    Un saludo,
    Just a simple question...
    Why 'approved by' and 'approved date' properties are only for Drawings?
    Some companies also will want to set the approved date and approved by for their Parts, Assemblies, and Part Studios
    Un saludo,
    Un saludo,
    Brian_McVeighBrian_McVeigh Member Posts: 78 PRO
    Thanks for the tessellation settings!  If I up the settings on a large assembly/part studio what will the performance limiting factor be?  Hardware on user end (and graphics or cpu?), internet connection speed, or will it be limited on the server side?
    Hi Folks.
    I really like the new matey-gizmo-HUD but with one exception.
    In everything Onshape a green icon with a white tick is "accept current action", but here the enter key does that and the same icon starts a new instance.
    I love the new instance option but not with that icon.
    Could I suggest the the current icon just accept the current mate and then stops, and a new icon (maybe the same check but with an additional horizontal arrow) accepts the current mate and moves onto another one?
    Cheers,
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,396
    @Brian_McVeigh the only difference is the number of triangles that must be sent and rendered. There will be a slight hit in the "loading graphics" phase and frames per second during rotation will be lower depending upon the graphics hardware. Nice thing is that you can selectively choose which parts have higher tessellation, so the performance hit is not exponential.
    rachel_ardenrachel_arden Member Posts: 14 ✭✭
    emagdalenaC2C
    From my understanding this is a new use of the metadata, not an introduction of the feature. Parts, Assemblies and Drawings can all be released, and the releases will record who and when approved it. This update is so that this data (who and when) can now appear and be updated on a drawing when it is released, without having to manually put it in before hand.
    mike_hölschermike_hölscher Member Posts: 105 PRO
    Really needed the flat editing! The implementation is not what I expected but we'll see how it turns out.
    First remarks:
    - Is there no origin in flat sheet metal view?
    - Fullscreen mode for flat editing?
    @mike_hölscher  - your suggestion of a 'full screen mode' is a good one - thank you.
    Re an origin - because the layout of the flat is entirely dependent on which edges are open and which are bends, it would not be a good idea to dimension to an origin as the faces could change position relative to it.
    Philip Thomas - Onshape
    @mike_hölscher
    Yes, there is no origin in the sheet metal flat view.  Since the sheet metal flat patterns can move around in that area (if additional parts are created by splitting parts, or joined together with a tab) the global coordinate system actually ends up being less useful than you would think.  References should be made to geometry of the part you are sketching on.
    There is no direct fullscreen for the sheet metal flat view, but you can grab the dividers and slide them around to make the page look closer to what you want:
    @Jake_Rosenfeld and @philip_thomas
    Thanks for the replies and clarification. I now understand about the origin. I will change my modelling approach with this in mind.
    I was doing the exact thing Jake shows in the screenshot. But since my sketch on the flat is like my master sketch with lots of stuff on it I would like to take advantage of my whole screen, and not keep on wasting time dragging dividers back and forth all the time, experimenting with stuff  the master sketch in the flat.
    Tony_C_Tony_C_ Member Posts: 272 PRO
    I like the idea of the new mating quick window.  But shouldn't it have the offset options in there also?   Many of my mates require an offset so I'm still needing to go back to the original old window once I click my 2nd mate.
    edited June 2018
    @Tony_C_ I think we are looking at adding some more controls but also know that we don't want to clutter up your mouse area too much. I would recommend generating an improvement to vote on for that. I've found the following workflow to be particularly fast with the new update:
    Going through and setting up all of my mates in a particular assembly/subassembly first. I didn't think the toolbar would be much faster than 'Shift+enter' but while recording the what's new video I was proven wrong.
    After all the mates are complete, go back and double-click mates to edit and adjust the positioning and offsets. The mouse travel is reduced from the mates list and mate dialog. Now, I understand that based on the assembly, this is not always an ideal workflow.
    lanalana Onshape Employees Posts: 697
    edited June 2018
    @mike_hölscher
    I'd like to understand your sheet metal workflow better. Could you please share a screen shot of an a sample sketch/completed part?
