Version Naming Conventions
NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,980 image
Hi fellow FeatureScripters!
As you know, it can be a difficult task to find the original document that a custom feature was created in so you can add it to your toolbar. With so many copies of each document flying around, it can look something like this:
However, if you name your versions they stand out a little better - in the image above I have prefixed each version with "Official" or "Original". Any ideas for a better naming convention?
Also, it is worth renaming "Main" to "Official" for when searching for a document from the documents page. Open to suggestions if anybody has a better idea?
Thanks.
    Version naming can solve the problem to the some point, but you still can't be sure that it is original. Authors name field would give the best guarantee.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    Good idea @NeilCooke , As long as the message gets out to all the FS writers, and people who branch specify that as well.. It should help clear up who's is the original
    Also being able to add one's own branch in a public doc would cut down on the copies in the first place...
    O.S.
    I can certainly go through and update version names on my scripts, but I think this is a more systematic issue.
    Sorting search by links/copies would help, but really a more Github-like "fork/modify/pull request" workflow (where you can also follow links from forked copy to parent to find the original) would solve this both for FeatureScripts and geometry public documents.
    Arul Suresh
    It seems like we think alike @owen_sparks =)=)
    I'll chose to take that as a compliment, so thank-you  :p
