Fillets and Chamfers (Combined Feature)
Don_Van_ZileDon_Van_Zile Member Posts: 195 PRO
To whom it may concern @Onshape Development,
I'm curious since the Extrude feature contains a Multi-Tool/Function approach why that same philosophy of "Feature Interchangeability" wasn't used for Fillet's and Chamfer's? I would think it would've been nice to simply switch to/from a fillet definition to chamfer and vice versa maintaining the Edge/Face ID's for downstream feature items potentially.
Was any thought given to this and abandoned or...?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,962 PRO
    I agree, this is pretty much the same thing. Solidworks added the ability to change between either an update or 2 ago. It would be nice addition for Onshape as well, also freeing up a button.
    The option to change the type of a mate was added a while back, I'd love to see this flexibility added here.
    O.S.
    @Don_Van_Zile
    Put it up for voting as improvement request.
    For me this would be consistent approach as it's like changing to different router blade on cnc but run the same path.
    +1 :+1:
    By the way, I'm not sure if @Onshape pushes notice to anyone? Can you confirm this @lougallo
    I think that should push some general notice to selected Onshape employees..
  • Don_Van_ZileDon_Van_Zile Member Posts: 195 PRO
    3dcad said:
    @Don_Van_Zile
    +1 :+1:
    Done!
    https://forum.onshape.com/discussion/9951/part-studio-fillets-and-chamfers-combined-feature-for-interchangeability-between-the-two/p1?new=1
    Vote cast.
    I will be releasing details designed for low volume machining and contain chamfers. However, in the future, we may make high-volume and change the manufacturing requirement to castings and have to require a lot of filleting etc... It would be unique to be able to switch back and forth in these simplistic scenarios without blowing up downstream features like we do today.
    Again, it would be awesome in Modern Cad not to have to worry about Future manufacturing methods making the designer cringe having to make the necessary CAD changes.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,241
    It should be very simple to write a custom combined fillet/chamfer feature -- perhaps that would address the need?
    A custom feature script if possible would be great and I'm sure would be popular. Where to start...?   :)
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,062 ✭✭✭✭✭
