Version Naming Conventions
NeilCooke
Moderator, Onshape Employees Posts: 5,376
Hi fellow FeatureScripters!
As you know, it can be a difficult task to find the original document that a custom feature was created in so you can add it to your toolbar. With so many copies of each document flying around, it can look something like this:
However, if you name your versions they stand out a little better - in the image above I have prefixed each version with "Official" or "Original". Any ideas for a better naming convention?
Also, it is worth renaming "Main" to "Official" for when searching for a document from the documents page. Open to suggestions if anybody has a better idea?
Thanks.
Thanks.
3
Cheers, Owen.
What about automatically marking all copies and give option to search/view only originals?
Sorting search by links/copies would help, but really a more Github-like "fork/modify/pull request" workflow (where you can also follow links from forked copy to parent to find the original) would solve this both for FeatureScripts and geometry public documents.
