Library menu
Good afternoon,
I was wondering if is any way to do a similar filter but using our own library.
Is there any Feature Script to do this (e.g. similar to  beam )?
Thank you
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,980 PRO
    That could mostly be done using configurations. But only one part at a time, not nearly as sofisticated as the standard content example you show
  • tecnico2_alvetecnico2_alve Member Posts: 3 PRO
    Thanks John, but this is not what I´m looking for.
    edited September 2018
    I'd also like my own content to show up as standard content.  There is no way to do this at the moment, we are relying on what Onshape decide to add in. Open Source content would be good which is created either privately or publically and be able to be added via user preference to the Onshape standard library.  I am also hoping vendors will get on board and add content.
    I know, but it's the best we can do for now
  • Don_Van_ZileDon_Van_Zile Member Posts: 195 PRO
    I too would love this ability mentioned by the OP with our own library; good idea @tecnico2_alve
    Don't forget what was mentioned in this thead:
    https://forum.onshape.com/discussion/9249/standard-content-component-requests/p1
    Hmm...
