How to make part name match solidworks part file name while importing
Vaish
Member Posts: 15 PRO
Hi all.
So I am importing my solidworks parts into onshape, However I would like the name of the parts to match the name of solidworks part file. Rather, only the part studio is getting the name but the part is named a random name, Part1. Is there a way to this, rather than go and rename every part in every part studio? I want to be able to reuse my parts in assemblies and with the current setup, on the left, I can only see Part1 for any file I import.
NeilCooke
Moderator, Onshape Employees Posts: 5,927
Correct. Please create an improvement request.Senior Director, Technical Services, EMEA5
if you import the project as a packandgo to zip. Then it will name each part by file name, this works for virtual parts as well.
If you import a step file it will maintain it's file name also
@lougallo is this a bug with the solidworks part importer?
Looked at pack'n go zip, step & parasolids exports. All these created the same thing inside OS.
All parts from the multi-body parts came in as the file name and not the body name. Didn't matter how it was transferred.
I found no way to get the body names to transfer from SW to OS. oh well....
So I didn't stop there, I fixed the names in OS and sent them back to SW through a parasolids file. They imported as 'imported', no names appeared.
So I didn't stop there, I read the parasolids back into SW that it created to see what it would do if I made it eat it's own garbage. The names didn't come in and were replaced with "imported".
So...... I didn't stop there, I took the cleaned up file created in OS, exported, then read it back in. All the names were there.
This is by all means not scientific in anyway, but I doubt we'll ever get body names out of SW. From what I can tell, OS is working properly and will use body names if they are present through an export.
Dang! body names would be nice.
