scaling an assembly?
fightingtorque
OS Professional Posts: 10 ✭
I have an assembly - it is a logo/ badge consisting of several letters and a backing. I want to bring this into a new part I am designing but I need to alter the size and aspect ratio to fit. I could transform all the individual components and then rebuild it, but there is quite a lot of work in creating the assembly (each letter is positioned via 3 planar mates) so I would like to be able to bring that assembly into a part studio and transform it as a whole, is that possible?
Ideally I would also like to perform some other mods to it (make the top curved by passing a curved "extrude remove" over it) so it would be best to have it in a part studio. The individual letters were not sketched up in the current layout
Thanks,
Gav
Thanks,
Gav
Transform also supports uniform and non uniform scaling as well as the moving of parts.
That said, modifying the letters before they are put into the assembly may be the easier way.
Hard to say without being able to see the document.
(it will take 5 minutes )
So the assembly of the letters into the backing pieces predates the component is now sat on. If the letters and their backing could be scaled to fit the space for them, that is good. If there was a way that it could be like that and in a part studio, that's also great / even better.
thanks for looking!
Gav
https://cad.onshape.com/documents/5b1f283f9495a2c1dc470632/w/47fe4ebff42e0adb70ea13d9/e/92ef58defe837e77ce77c193
Created using in-context editing, transform and boolean.
So I don't understand how you made the steps that brought the badge and letters into the existing part studio, generating those little arrows next to the transform command?
If you wan't to keep letters separated, use derive to add them to frame.
ps. This community is purely awesome.
If so, you should be able to follow philip_thomas original advice:
