"single command per pick" option like solidworks?
    Say what now?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,067 PRO
    edited November 2018
    Say what now?
    It's the first option you turn off when you install SW ;p
    It turns this work flow to sketch a chain of 3 line segments:
    Click Line tool (or press L)
    Click first point
    Click second point
    Click third point
    Click fourth point
    Press ESC
    Into this monstrosity:
    click Line tool (or press L)
    click first point
    click second point
    click second point again
    click third point
    click third point again
    click fourth point
    @edward_anderson if you click-hold-drag-release you will only sketch one line segment at a time.
    Double click ends line but keeps tool selected..
    Thanks Gents :+1:
  • edward_andersonedward_anderson Member Posts: 4 PRO
    Thanks all.
  • David_BoneDavid_Bone Member Posts: 47 ✭✭✭
    For unconnected line segments you can always click-start/drag-release-end to make a series of unconnected lines.
