"single command per pick" option like solidworks?
edward_anderson
Member Posts: 4 PRO
NeilCooke
Moderator, Onshape Employees Posts: 6,004
No, there is no such option. You can press the Esc key after every pick to cancel the command if you wish.Senior Director, Technical Services, EMEA5
It turns this work flow to sketch a chain of 3 line segments:
Click Line tool (or press L)
Click first point
Click second point
Click third point
Click fourth point
Press ESC
Into this monstrosity:
click Line tool (or press L)
click first point
click second point
click second point again
click third point
click third point again
click fourth point
@edward_anderson if you click-hold-drag-release you will only sketch one line segment at a time.
