Flat sheet metal part as a solid?
Hi,
Is it possible to convert the flattened sheet metal pattern into a new solid part? I've use the feature to create the net of a shape for a fan duct, and I want to be able to 3D print the result (at .6mm thick) and fold it up. However I'd like to add a couple off internal tabs for alignment which would be printed in place. I'd also like to be able to thin the bend lines to assist with the fold up.
Thanks in advance for any help.
Cheers
Steve
Cheers
Steve
Jason_S Moderator, Onshape Employees, Developers Posts: 218
Don' worry, this is being worked on. Stay tunedSupport & QA2
It would be nice if we had more access to the flat pattern, other than just inside the view port on the right.
That would also solve the problem of not being able to insert a flat pattern into an EXISTING drawing
A workaround for now, if you have already done it, would be to create a drawing export with a flat pattern, export as a dxf, then re-import into your part studio and extrude.
yes, It is trivial to me too; BUT it happens..
Any opertunity to eliminate a potential for failure. I'm all for it.
I am always confident of 1:1 when RMB and dxf export off the model, it's when the drawing sheet gets involved that the problems start. I am sure in the next few releases they will have a dxf export from the flat pattern. Maybe with a check box to include bend line and scale notation.
i'm also trying to export a flat pattern as X_T. my manufacturer (for his reasons) prefer it that way.
can it be done?
couldn't find the answer else were.
Thanks
Insert into assembly then export from there.
@steve_kingsley
Here is a feature that will fold a flat sheet metal part: https://forum.onshape.com/discussion/comment/46659/#Comment_46659
This is what you want @julian_juarez @steve_kingsley
https://cad.onshape.com/documents/ec05740ca8f236e5a24eceec
