Need a warning message when creating drawing of a part studio vs. a part
steven_elliott555
Member Posts: 24 PRO
In this example - I created a drawing by right clicking the part studio from the tab manager to create a drawing (This particular part studio only had one part)
After spending a significant amount of time adding drawing details and dimensions - I went back to update the part properties so the information linked back to the drawing would auto-populate.
The information did not carry over because I had created a drawing of a "part studio" and NOT the "part" itself. (see image below)
Currently there is no means of redirecting your drawing to another source through the "sheet properties" tab and this drawing will ALWAYS look at the "part studio" properties.
Potential Solutions:
1. There needs to be a warning message that pops up to warn the user that OnShape will tie the drawing to "part studio" and not the "part". (see image below)
or
2. There needs to a method of redirecting a sheet properties link to another Onshape object.
or
7
IMHO this should be disabled by default in the settings
I had a detailer do my drawings and that is his biggest problem.
I make him re detail half the project every time because of this common mistake
Otherwise you are 100% Correct. But many people have bad practices because they dont want or have the time to learn better methods. Esspecially hobbiests
