have any onshapers imported sketchup files into onshape with tips to do this?
I am working with a client that is stuck on sketchup becuase it's what he knows. I have imported sketchup files into solidworks in the past with enough success to to have enoguh of a reference to remodel it in SolidWorks. anyone have any tips for getting useful data out of sketchup to use in onshape?
LearnOnshape facebook group
I have a lot of files I would like to get away from Sketchup and into Onshape.
(1) Install an export-to-stl plugin to Sketchup.
(2) Use it to export that STL
(3) Use MeshFix (or another STL fixer) to repair some oddities in the exported STL. This may have been related to the particular models I was trying to export. But this was a necessary step for me to successfully import.
(4) Import the fixed STL file. If this fails, then no part studio will be created. If it succeeds, then two tabs (one for the file and one for a part studio) will be created.
(5) Use onshape tools and the points on the mesh to create a solid that matches the mesh.
(6) Now I have a full onshape part I can use in assemblies or to help with designing mating parts, etc.
It works well enough that I can use most objects for measurement reference to design my own version.
