Improvements to Onshape - January 18th, 2019
2»
  • mike_hölschermike_hölscher Member Posts: 110 PRO
    @NeilCooke I will create an IR.
    You mean, in the case where there are already two dimensions 'above' each other and you want to add a third one in between, if the top dimension should move up OR the bottom one should move down automatically? In case of this automatic moving of one of the two I guess I would always like the dimension closest to the part to stay stationary and have the furthest one move out. But really, that is already al lot more advanced as I intended it to be. If the dimensions would be on top each other first and afterwards snap one of them to the equal spacing above each other that would be fine also.
  • bill_danielsbill_daniels Member Posts: 278 ✭✭✭
    I just used the DropBox integration for the first time - fantastic!  However, it would be nice to have a "Batch Export" function.  Sometimes a vendor needs a bunch of files to bid on a project.  Exporting them one at a time is a chore.
    @bill_daniels Funny you say so directly after my comment. I have an improvement request on exaxtly that, which has been growing steadily the last weeks :smile:
    https://forum.onshape.com/discussion/6947/batch-export-files#latest
    Please vote up.
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    Love the folder option in part studio.
    Way more organized and easier to find things when the list is shortened.
    It would be great If the dropbox or drive link could remember you last directory, or selection of saved directories. I find it hard navigating everytime.
