How do I remove a portion of an extruded face, but not all of it.
mark_rogers151
Member Posts: 3 ✭
john_mcclary
Member, Developers Posts: 4,002 PRO
Because the rear face is larger than the front face, I'd start with the rear face and draw a triangle section to remove, then extrude/remove out
6
Something like in the picture attached.
https://cad.onshape.com/documents/1c21705814bea17ac845277f/w/e95dd9c41a03966e558cf5b9/e/95a051408414fb48bdd2a318
1 draw a sketch on the flat front face of your part
2 Project the outline of the face with the "Use" feature.
3 Add a line in the sketch where your want the cut.
4 extrude the triangular sketch region with the following parameters "remove" "up to face" and select the back face of that tab.
Does that make sense? If not I'm sure someone will demonstrate.
Cheers, Owen.
Learning Center
