How do I remove a portion of an extruded face, but not all of it.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,859
    Not really sure what you are asking? Please review this check list for a prompt response: https://forum.onshape.com/discussion/9107/forum-post-checklist
  • mark_rogers151mark_rogers151 Member Posts: 3
    edited February 2019
    I am trying to remove the highlighted part in the screenshot. The tab on the end of the part needs to slope down, which I am trying to achieve by removing the highlighted section.
    Something like in the picture attached.
    If I delete the faces then I am left with a hollow section and I can't work out how to do have keep the sloping face solid. I have posted the url to the document below:
    https://cad.onshape.com/documents/1c21705814bea17ac845277f/w/e95dd9c41a03966e558cf5b9/e/95a051408414fb48bdd2a318
    Hi.
    1 draw a sketch on the flat front face of your part
    2 Project the outline of the face with the "Use" feature.
    3 Add a line in the sketch where your want the cut.
    4 extrude the triangular sketch region with the following parameters "remove" "up to face" and select the back face of that tab.
    Does that make sense? If not I'm sure someone will demonstrate.
    Cheers, Owen.
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    @mark_rogers151, it seems like you're pretty new to CAD modeling. It's helpful to learn by doing, but it would also help to get you up to speed on the basics. Going through the Onshape fundamentals tutorials would probably answer a lot of your questions.
    Learning Center
    Perfect...Thanks John. That was so simple.
