Hole in the Floor
famadorian
Member Posts: 390 ✭✭✭
I understand how I can add a hole by first extruding a box then extruding a removal of an offset, but that sort of makes it necessary to clutter up the master sketch.
I was trying to be more tidy and do the hole later, preferably in a derived document, but then:
1. there is no hole
2. we can see the walls of the hole protruding through some of the surface of the floor
This is kinda hard to explain for me, so here's an image and Onshape document
https://cad.onshape.com/documents/fef041ae74d0f252abb20c48/v/87d0959539c7a468d944030a/e/9683a59e814ea54dc8b8bf85
Here's the master sketch:
1. there is no hole
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
At first, didn't vote you down. Don't know why someone did since it effectively keeps anyone from answering.. There's no such thing as stupid question in this forum and you included descriptive images & link to public doc
If you wan't to extrude like that and use part of extrude to cut other parts then boolean is the tool for you.
https://cad.onshape.com/help/Content/booleanparts.htm?Highlight=boolean
I would do it into master sketch though, it's easier to edit later when they are all in same sketch and it keeps your feature list shorter.//rami6
(BTW Also didn't down vote)
