Triad Manipulator Update
I would like to see an improvement with the Triad Manipulator. Currently, the design of the manipulator resembles this:
I would like to see the manipulators be more opaque. Similar to the following:
3
I agree with the colors @owen_sparks is suggesting, but I would keep the current Onshape style manipulator. That SW one I end up choosing the wrong direction/rotation by accident because they overlap so much and are so large. If the X axis is in the same position as you show the Onshape style one, you would not be able to grab it without rotating your view. At least with the smaller grips with Onshape's there are very few angles where it is impossible to grab what you need.
One improve I'd like to see is using the Ball with a modifier key to drag and snap a part in position.
