How can I get a useful 2D print on my printer.
It seems like I have to position things 3 or 4 times every time I try to print out dimensions I have assigned to a part, either it is to big for my printer to get it all, to small to read, positioned so I miss part of the drawing, etc. Is there a way to know I'm going to get what I see printed to my printer.
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
@Bill H You are correct we are missing a preview that you can modify to indicate where things will be located. I have the most luck using Landscape and A5.
I will attach you to the improvement for this. If you use Show dimensions on the sketches that contain the values you are after for that view, they will show up as well. You could also just edit the sketch and print something like this:
Keep an eye out for a ticket soon. ~Lou
Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5 -
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
@3Dexter : on the offchance that you are not familiar with the RMB abbreviation : Right Mouse Button5
1. Document options -> Print...
2. Print preview (I did a bad job).
There are still occasions where the quickest way of progressing a design, whether at the conceptual or the detail stage, is to hand sketch on a printout (or a succession of them) and it's helpful if this can be done at a nominated scale.
Did you try 123d Design or Fusion360 ?
Both have evolved lightning fast over the past 12months.
On shape is still developing these work features.
I wish they would grab a few drawing features from Siemens Solidedge ST7
Below is a quick snip of a sketch in Onshape I could size it to whatever part or size of the screen I wished.
Dave
I think it would be a great feature to do a scale print mostly especially 1:1 straight from the part studio, no drawings involved, I am sure this would be pretty easy to add in.
I also like the idea of being able to add annotations, ie MBD's that could be turned on to show on these prints (not using sketches) also for 3d viewing of parts during manufacture. Maybe these could even be at the part level. eg. when in the part studio you could RMB on the part in the parts list to hide show annotation for that part.
@brucebartlett still can not save in PNG without the white background!
Sample images below.
+1 for me too
Except if it's easy task to add 'transparent background' check box to print dialog..
Sorry Bill, you will be getting a bit stick of this conversation on your thread.
