Where can I get nuts and bolts?
The certified libraries are rubbish. Is uploading an old SW library the best solution?
owen_sparks Member, Developers Posts: 2,660 PRO
Another approach worth mentioning.I've been playing around with making a company standard content custom feature. It allows you to place components at target sketch points or mate connectors and where appropriate cut voids for them to fit into.For stuff you have good models of it's a nice way to wrap them up into an easy to use library.The really nice thing is they can be configured just like any other feature (unlike a derive), so if you want a version of a product with pressure transducers and another with mil-spec connectors it's just a config setting.Cheers, Owen S.Business Systems and Configuration Controller
HWM-Water Ltd7 -
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,145 PRO
Jason_S said:@bill_rayner, what can we add to make it not rubbish?
5
But I was hoping for a featurescript solution, and seem to remember one being worked on a few years back. I'm quite happy to have the parts dumped at the origin so I can place it with connectors. Is that around?
I absolutely agree about Onshape support; I've had more support from Onshape in the past 4 years than the entire 40 years of CAD before that. And the suport was deeds, not just words.
Onshape's Standard Content!
How come a search on nuts and bolts didn't bring that up? There it was lurking in clear view. Perfect. Just insert bolts into an assembly, then re-insert them into a part studio.HWM-Water Ltd
It just wont be a boolean subtract + offset, which is what I assume you are doing.
Hole is better in ways because it will also dimension it properly in drawings.
Um, because I can't see how I can do it any other way. But obviously there is; please give me a hint.
We're really spoilt for choice on how to do things in Onshape, so I find that I get into the habit of using one method to do all things. Revisiting "in-context" makes me realise it should usually be my first choice: I lost a whole sketch-full of relations the other day from choosing an inappropriate workaround. The trick is to assume everything you do is going to be used for final production - no shortcuts! That's really hard when you're on a roll.
