SHEET METAL COUNTERSUNK HOLE ISSUE
john_mcclary
Member, Developers Posts: 4,063 PRO
active sheet-metal parts can only have cuts perpendicular to the top face. (anything that can be done on a standard laser table)
you will need to add a "Finish Sheet-Metal" feature in order to cut features like countersinks.
(anything that will happen after the part has been cut from the laser table)4
That would be impressive, but currently I don't think it is possible. Sheetmetal treats faces almost as if they are infinitely thin, finding where the hole is and then thickening (that's not how it technically does it, but much to the same affect).
At the very least, even if the model required to be finished before adding countersinks, It would be great to have the option of which features to show and which to hide on flat pattern drawings instead of being limited to Onshape's assumptions on manufacturing methods.
Has anyone came up with a temporary solution for this? I need to get my drawings to fabrication ASAP and this has caused an unexpected road block.
