Making sketchs internal to operations
Hi, would be great if the sketchs could be make internal to the operations, then the history tree could be more easy to navigate. NX has the option to make internal or external, so you can use it in several operations or keep it hide.
My ideal workflow would be start with the sketch command, then select the extrude/revolve/loft command, and then in the operation window have the check to make it internal/external, so when you finish the operation you have the work done.
Regards, and keep it improving this great software!
3
All this escenarios are availble now on NX, and, for me at least, are very usefull.
Regards!
I haven't seen NX but I suppose some + sign for expanding feature to see the sketch? This would ease up custom naming because it would be enough if features are named.
Since we are talking about nesting, there are two different aspects to nesting that are important to me. One is the visual aspect; how the sketch is shown in the feature tree. The other aspect is scope, what things are allowed to reference it.
In creo internal sketches cannot be used for other features and are removed from the feature tree. In solidworks internal sketches can be used for other features and are available in the feature tree as children of the dependant features.
I prefer the solidworks approach where the nesting is visual and not scope.
Dave
Ariel, WA
Dave
Ariel, WA
Dave
Ariel, WA
As far as rolling the sketch into a feature I suppose it would be rolled into the first feature it's used with. But as suggested a switch/option to roll or not would be helpful for sketches used on multiple features.
The needs for organizing the feature tree have come up a few times. Here's one of the bigger threads;
Dave
Nice looking router. Are you building one.
Dave
Ariel, WA
From a professional viewpoint I have issues with with hobby desktop machines, but that's a different conversation.
1) Assign an (automatic) color to the name of each part on the desing studio, and color every feature name on the tree with the same color. Maybe a special color can be defined for shared features. Problem is that there are not much clear different colors (and not mention if the designer is colorblind)
2) Make that the name of the feature take (automatic) the name of the part being applied (ie Part1_Extrusion; Part2_Revolution...). Again for the shared features a special name can be defined
In both cases this could be reinforced if when a part is selected on the part list, all the features be highlited in the tree as well, and having a way to sort/resort the tree by colors or names or historicly.
Feature 1
+ Extrude 1
^- Sketch 1
Feature 2
But Sketch 1 is regenerated before Extrude 1, so the tree is misleading -- placement of the rollback bar and what can reference what becomes confusing. I wonder if better feature tree filtering tools (including the ability to filter out "consumed" sketches) as well as general grouping would address the problems that internal sketches are meant to address.
I like the parts list but want to drag parts to reorder the tree, will not always be possible but would work sometimes. What I also do a lot is isolate back too a single part on my screen, and will often use "Hide other parts", RMB from the parts list or from the part in the workspace. When i do this I will be focusing my attention onto the single part and would also like to see just see features related to this part in the tree. Ideally I would like the tree to collapse to show only the features related to the part, turn on another part and your see the combined features. Not sure how that would work, or if it would work.
Dave
Ariel, WA
Yes
