Another answer to question you didn't ask, Onshape is 3D mcad software. But the reason why I commented with tagging you in is that I create a lot of layout plans and design furniture for living using this amazing tool. You just need to remember it's not built for that and you shouldn't expect such. So as a tip, figure out a way to keep your sketches compact and simple and you will enjoy optimal performance using Onshape for blueprints, layouts, even landscapes or whatever.
Linked[in]
The next update will be 1.100 or 2.01?
Well, they are software developers, so Mountain Dew and Funyuns
When is the next update coming out?
This Friday?
I have already got into trouble twice for trying to stuff extra stuff into this release - they are working hard to get it out.
Just remember - sometimes a lot of work goes on in the background that you don't necessarily see as a 'new' functionality!
