How to add an unlimited number of predecates
Evan_ReeseEvan_Reese Member Posts: 2,066 PRO
I'm wanting to create a Multi-Variable feature that allows for several variable declarations at once. I'm trying to figure out the best way to structure the UI for that. Ideally, the user should be able to click a button to add another variable, or (less preferably) to be able to use a count parameter at the top to say how many there should be. Here's what I've got so far, but the code seems clumsy. I'm just nesting if statements for each additional variable input, so there's a limit on how many variables someone could declare. Who knows, maybe I could just limit it to 5 and that's a good thing so the dialog window doesn't go off-screen. Thoughts?
Evan Reese / Principal and Industrial Designer with Ovyl
Website: ovyl.io
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,401
    Have you tried array parameters? That is the mechanism used in Loft and Fill to add multiple inputs.
    the execution above is also not great because if I uncheck boolean 1, then everything after it disappears. So anyway, it's got some issues, and I'm trying to figure out how clean this could be
    Website: ovyl.io
    I looked into it a bit but wasn't sure it would work for me since I'm still not sure how I'd add a parameter. With Fill, each edge query opens up a parameter in the array with selections for continuity. With mine, I don't know how to tell Featurescript to add another parameter, since I'm not selecting anything in the model. Could I control that some other way? if so, you're right, Array Parameter is what I need.
    Website: ovyl.io
    You should probably ignore me - array parameters have limited logic capability so it may be difficult to get the full variable functionality you need.
    @NeilCooke haha I appreciate the input.
    @kevin_o_toole_1 That seems like exactly what I'm looking for. I'm out of time to test it right now, but I'll report back once I do.
    Website: ovyl.io
    kevin_o_toole_1kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565
    Unfortunately Neil rightly points out that your feature with array parameters will unfortunately run into a limitation of array parameters that parameter visibility can depend on the primary map "definition" (like if (definition.type == Type.A)) but can't depend on individual array items (like if (profile.type == Type.A)).
    You can vote on the improvement request to support the latter here: https://forum.onshape.com/discussion/7628/conditional-visibility-of-array-parameters/p1
    So that might prevent me from having different enums for variable type? I feel that's not ideal, but also not a killer. I can always just manually add the units to the variable itself and achieve the same thing, right? so instead of selecting "angle" and typing "50", can't I just type "50 deg" and get the same result? It would be good enough.
    Website: ovyl.io
    Correct. You could also have a single "Length/Angle/Number/Any" control outside the array which controls all items... but now that I think about it I like your solution better.
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,178
    The reason we added Length/Angle/Number/Any to variables was primarily to get automatic units completion since like 90% of variables users want are lengths.  If you don't need it, it's good enough.
    hey, thanks for the input everyone! I got it working pretty much as expected. Its a nice balance between making a ton of individual variable features, and actually writing them into a custom feature that I put at the top. I think it's approachable for most users too... now, why is my code so much shorter than the actual Variable feature? Is there some crucial safeguard there that I should add here?
    Here's the link.
    Website: ovyl.io
    one more thing I think is important with this feature is the ability to reference previous variables in the same feature. I want to be able to use it as a container for similar variables, so I'd use a new Multi-Variable feature for "Size Variables", "Wall Thicknesses", and "Draft Angles" and many of them should be reference other variables in the array like #nominal = 2.5mm and #rib = #nominal*.6
    I expected this to work as long as #nominal is declared before #rib, since the for loop is iterating through, and by the time it's on the second iteration #nominal has already been declared. It doesn't seem to work that way, which limits the usefulness of the feature, at least for the way I work. Any pointers on how to get this working? Can it even be done?
    Website: ovyl.io
    Makes sense. The default to length reduces user error.
    Website: ovyl.io
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    @Evan_Reese
    It most likely will not be able to be done because Onshape actually works out the values before the feature even starts, so that is why you cannot reference a variable created in the feature. :(
    edited December 2019
    @Evan_Reese
    aw man! Couldn't you lie to me or something?
    I think I see what you're saying. It loops through the whole predicate before it even starts executing the feature, so there's no way the values computed by the feature can feed back into the predicate. If they could, I could write recursive nonsense. Something like that?
    Before I give up on it completely, does anyone else have any tricks for something like this? I wonder if there might be a way to parse the values in the execution part of the code. I know getVariable() can reference an existing variable within one feature. I've started a new thread here since this seemed like a new topic.
    All I really want for Chirstmas is:
    1. make a feature to declare multiple variables at once
    2. let them reference each other
    3. not write a custom featurescript every time I want a bunch of variables. I want it to be accessible to users of all skill levels.
    Website: ovyl.io
    @MBartlett21
    not sure what I'm looking at here, but it seems like you're showing it working. If I enter the same values I'm getting an error. Care to expound a bit?
    Website: ovyl.io
    @Evan_Reese
    How about this:
    @Evan_Reese
    Here is the link: :)
    http://onsha.pe/documents/da7abfbf7607534743ef3e77
    Here is what I am doing:
    In the UI, the value parameters are strings, rather than using isAnything.
    The FeatureScript then passes those values to a little library that I made, which evaluates the value of the string, checking if it needs to use another variable and calculating the other variable if so (Circular references are also checked).
    Those values are then set for each variable and populated into the Variable summary notification
    @MBartlett21
    I'm so far from being able to write something like that. I'll dig into how you did it after hours sometimes and I'm sure I'll learn a lot. Thank you for taking the time. I'll probably be back with questions once I've sat with it a while.
    Website: ovyl.io
    @Evan_Reese
    Here is the library that I am using:
    http://onsha.pe/documents/429fd7dda5f0fdb93833a34a
    It exports a function called evalExpression that takes a string and a map of variables.
    This function first splits the text into tokens. e.g: "5 + 5" => [5, "+", 5]
    It then checks for any variables that it needs that have not been calculated. If there is any needed variables, it returns an array of variable names that it needs.
    After this, it converts the tokens to Reverse Polish Notation (RPN). e.g: [5, "+", 5] => [5, 5, "+"]
    After it has been converted to RPN, it then evaluates the RPN and returns the end value.
    @MBartlett21
    Nice!
    @ilya_baran
    Would there be any way to get autocomplete for the functions and variables to work with this, or would it have to be supported internally?
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,901 PRO
    That's why I love Morgan. He doesn't believe in 'good enough' :)
    Sorry, we'd have to support autocomplete.  BTW, we are (also) planning to do multiple variables more easily at some point, probably via a table :)
    :D
    I've been waiting my whole life for this.
    Hopefully, they could be set up as globals for the whole doc, and maybe even linked between documents the same way parts are.
    Website: ovyl.io
    @MBartlett21 thanks for the breakdown of the library and how you're doing it! I'll study it when I have time.
    Website: ovyl.io
