Next year improvement request
bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 995 ✭✭✭✭✭
With another year of great Onshape improvements in the books, what improvements would you like to see for 2020?
Here are a few of mine:
CHANGE ORIENTATION OF FLAT PATTERN IN DRAWINGS
https://forum.onshape.com/discussion/8499/change-orientation-of-flat-pattern-in-drawings#latest
SKETCHING IN DRAWINGS
https://forum.onshape.com/discussion/9784/sketching-in-drawings#latest
CHANGE DIRCTION OF BENDS IN FLAT PATTERN
https://forum.onshape.com/discussion/9404/change-dirction-of-bends-in-flat-pattern#latest
CHANGE THE DEFAULT CALL OUT OF THE ANGLE IN DRAWINGS TO THE COMPLIMENTARY OF THAT ANGLE
https://forum.onshape.com/discussion/8500/change-the-default-call-out-of-the-angle-in-drawings-to-the-complimentary-of-that-angle#latest
Bryan Lagrange
Twitter: @BryanLAGdesign
  • ian_bruinsmian_bruinsm Member Posts: 1
    Yes, I have been watching this for a long time. Decals, and Colour individual faces (Surfaces). OnShape it ideal for my needs. I often have to massage small electronic parts imported from STEP files. But they normally come in as single colour items. I need to have coloured on different surfaces or even better apply a decal to make them more realistic in Altium (my PCB CAD package).
  • Ste_WilsonSte_Wilson Member Posts: 582 EDU
    I'd like to be able to assign threads to shafts in the same way threads can be assigned to holes.
    Also the animation thing...If it's good enough for the OnShape front page to have a nice animated assembly, then I WANT IT TOO!!!
    Ability to pull dimension in from model on a drawing.
    And the sharing thing mentioned above.  It would be good to be able to embed a shared view in another webpage.
