Selcting mulitple entities/tools for the Split command or using surfaces with Boolean features.
clayton_ertley
Member Posts: 58 ✭✭
With CAD in general I mostly design Rubik's puzzles among other mechanical things.
The way I do this is to use a revolve a sketch profile about the origin of the shape I am using. It requires an invariable use of 5-50 surface bodies. This can be extremely labor intensive as I am forced to do multiple split operations and that is made even harder by that face that I have to manually select the bodies to be split which get difficult as I progress( a standard 3x3x3 Rubik's 12 splits before it is completed). Currently in OnShape we can select multiple bodies to be split, but only one tool/plane/surface.
I have attached an image to display a simple version of my problem.
I am a Rhino and Solidworks user. Respectively you can use surfaces in Boolean operations and multiple surfaces AND bodies.
I feel like the development team already has a lot on their plate at the moment that makes me feel a little guilty, but I had to suggest this. Great work so far guys! As soon as I finish moving into my new place in the coming month or so I plan to pay for the pro account in order to help with your guys funding.
I wish you the best and thanks for reading my suggestion!
-Clay
-Clay
1
In every other cad program I preform on 1 split operation.
Maybe you could elaborate on your suggestion?
https://cad.onshape.com/documents/d29ff8e74a0f49809e533f48/w/48fedb2064cc4f30a27ee6e8/e/d2225c9e50db4df088eb880d
Here is the finished product(view and comment only):
https://cad.onshape.com/documents/6a7c64af7a8c4b8e874512c5/w/f9551adca811463680078e88/e/8d37876fc9c64539a52db547
I think they would have managed OK to machine up a prototype, but making female tooling, now THAT would have been a serious challenge.
Maybe doable on a manual Deckel, with ALL the bells and whistles...
@clayton_ertley great suggestion on using multiple tools, add it in as feedback. I can see MOTW coming up with that doc (place that on as a prefix for @lougallo to see when choosing model of the week contestants). Its a very long feature, how do you go navigating it?
https://cad.onshape.com/documents/5283d704088a4043bf84dd0d/w/40d246ccad6e4cee8aa77bd5/e/4eab66addd4e4cdeaf8475c4
If you want to see what the jumbling part, this guy explains it well enough:
https://www.youtube.com/watch?v=TagZmrnHmJQ
