Improvements to Onshape - January 7th, 2020
Moderator, Onshape Employees, Developers, csevp Posts: 218
edited January 2020 in New in Onshape
It's 2020, and we are starting early with an update that will help you improve productivity in the new year! This update focuses on a number of user-requested usability and drawing improvements. Let's dig in.
CAD IMPROVEMENTS
MEASURE TOOL IN ONSHAPE DRAWINGS
You can now measure in Onshape Drawings.
https://onshape.wistia.com/medias/0p06yu6syp
MIN/MAX DIMENSION IN ONSHAPE DRAWINGS
You will find a new Min/Max Dimension type in Onshape Drawings. This new dimension makes it easier to dimension to the inside or outside of arcs or circles.
https://onshape.wistia.com/medias/npndmcy9z0
GD&T EDGE EXTENSIONS
You can now create GD&T symbols that reference an edge with an edge extension as opposed to a leader with arrow.
https://onshape.wistia.com/medias/9rig0k5nds
MICROSOFT ONEDRIVE INTEGRATION
You can now integrate Microsoft OneDrive with your Onshape account.
https://onshape.wistia.com/medias/egd3eqsg2v
COMPOSITE PARTS FILTER IN ONSHAPE ASSEMBLIES
You can now filter by Composite parts when inserting into Onshape Assemblies. This was highly-requested by users after announcing this new feature a few months ago.
EXPORT IMPROVEMENTS
Those with export permissions can now export Linked Documents from the right-click context menu of an assembly. In the past you had to open the Linked Document and export from it.
PROFESSIONAL IMPROVEMENTS
EXPORT FROM RELEASE CANDIDATE DIALOG
You can now export directly from the Release candidate dialog in Onshape. This is especially useful for those that need to export released data as you no longer need to load the release and browse through the Document to export.
https://onshape.wistia.com/medias/o6tzcqu12e
LEARNING CENTER IMPROVEMENTS
A new course, Understanding Curves, has been added to the Onshape Learning Center to explain how to create the underlying framework for advanced part creation and surface models. This course is available to Standard, Professional, Enterprise, and Educational subscriptions.
Remember: The updates listed here are now live for all users when creating new Documents and over the next few days these features will also be available in Documents created before the date of this update.
  • Member Posts: 14 PRO
    Nice work! Drawing improvements are always welcome.
    Hugues Lessard
    Ingénieur de produits / Product Engineer
    Waste Robotics Inc. / www.wasterobotic.com
  • Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
    Sure, drawings improvements are very welcome
    Un saludo,
  • Member, Developers Posts: 3,944 PRO
    Cool beans
    Glad to see you are still improving drawings
  • Member Posts: 19 PRO
    Nice work developer team.
    Thanks,
    Effendi H.
  • Member, csevp Posts: 695 PRO
    Wow - the export from Release dialog is a HUGE time-saver.
    Thank you thank you thank you thank you!
  • Member, Developers Posts: 2,660 PRO
    Nice!!
    Will it be possible today/later to filter a featurescript instantiator for composite parts only?
    Cheers, Owen S.
  • Member Posts: 26 ✭✭
    From one point it's a big improvement to have one place for export each part, from the other hand you made it dependent from release process. From what I heard on the forum releasing is not as flawless so we avoid using it for now, and it means that though you now can say that you have this feature, it may be actually mostly unusable just like assembly items.
  • Member, Moderator, Onshape Employees, Developers, csevp Posts: 664
    Nice!!
    Cheers, Owen S.
    Unless I am misunderstanding, I believe this is possible:
    https://cad.onshape.com/FsDoc/library.html#newInstantiator-Id-map
    When you are creating your instantiator, you pass it a query that filters down to the composite parts only using a query like:
    https://cad.onshape.com/FsDoc/library.html#BodyType
    qBodyType(query, BodyType.COMPOSITE)
    ex.
    newInstantiator(id, {
                "partQuery": qBodyType(query, BodyType.COMPOSITE)
    Jake Ramsley
    Thanks @jakeramsley that's exactly what I'm after. Sorry for not reading the manual properly and seeing composite was already a body type.
    Will take it for a test-drive in the morning.
    Cheers, Owen.
  • Member Posts: 6
    I want to input Chinese directly on the drawing
  • Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
    edited January 2020
    Great to see another set of updates. The best thing ever is not having to worry about upgrades and just logging in for a new version.  It's great to see further improvements to drawings, they are a real joy use now and all these small improvements are the icing on the cake.  I am also liking the larger button in the insert which I think has only just turned up.  Also, I am now making use of the interference tool from a previous recent release, this is very handy and just saved me from a few drawing errors.
    Great to see some important improvements around release and exports but would be nice to have a bulk export button, for me, export for drawings in pdf's and dxf files from a release in one go would be a huge time saver.  Please, please keep working in this area as it's currently a real productivity killer at the highest-pressure point of projects.
    +100
    Edit:   make that +300 just for this release package alone...
    Yes Please! Print or export 300 approved drawings in one click from the product structure, as opposed to days spent navigating and printing/exporting 1 by 1.
    I was referring the the unique part step files that need to be exported for mfg.
    But yes, bulk export of anything is a high priority
    @john_mcclary I totally missed the context, I just saw the photo of the pile of drawings and thinking of the pain you have to go through to print them all. That is unless you use multi-sheet of which I don't.
    I do use multi sheet, mostly because of the export limitations.
    Otherwise I'd likely use multi-tab again just so I could do detailing cheats where you duplicate a sheet and replace reference.
  • Member, Developers Posts: 842 EDU
    mmm.  not pinned.  Holding breath....
    www.accuratepattern.com
    Yea, noticed it last night before bed... been checking in all morning... Not sure why they are un-pinning so early now.
    edited January 2020
    To mess with you of course!
    Mission Accomplished
    Lolz
  • Member Posts: 271 PRO
    CAD Engineering Manager
    edited January 2020
    Hopefully unpinned to make way for exploded views  ;). That would make me happy.  :)
  • Member Posts: 648 ✭✭✭✭
    But I just started using the assembly configurations + configured mates to do exploded views yesterday!
    I am holding off doing that in a project hoping it might be in the next release. If not, that's what I'll have to do.
