Simple question? well to me is very hard.....
Cannon_Fodder
Member Posts: 3 ✭
Hi Community,
I am trying to figure out how to make a slot in this object, i will try and explain.
I need to make a slot essentially in the vertical access, halfway into the object, the same size as the outer rounded section.
(as another rounded object is going to interface with the shaft that slide into teh hole.)
Basically i can do it with a Revolve of a appropriately sized rectangle.
But the problem is that when i create the rectangle, it is on one of the sketch planes that are in the wrong spot.
So how do you do this? what is the preferred method to ???MOVE??? the part, in this case the center of the circle to the correct position to use the revolve.
Or am i missing something basic here. If i have i am more than happy to learn.
I cant seem to find the right search terms to use to find the right answer. dumb i know but its go me stumped.
Thanks.
https://cad.onshape.com/documents/83c428b44a708fa5c8581b41/w/1c5414f8aa2ca30f7162edcc/e/c0142ce16f9456fffe7dfe1a
