Improvements to Onshape - January 7th, 2020
CAD IMPROVEMENTS
MEASURE TOOL IN ONSHAPE DRAWINGS
You can now measure in Onshape Drawings.MIN/MAX DIMENSION IN ONSHAPE DRAWINGS
You will find a new Min/Max Dimension type in Onshape Drawings. This new dimension makes it easier to dimension to the inside or outside of arcs or circles.GD&T EDGE EXTENSIONS
You can now create GD&T symbols that reference an edge with an edge extension as opposed to a leader with arrow.MICROSOFT ONEDRIVE INTEGRATION
You can now integrate Microsoft OneDrive with your Onshape account.COMPOSITE PARTS FILTER IN ONSHAPE ASSEMBLIES
You can now filter by Composite parts when inserting into Onshape Assemblies. This was highly-requested by users after announcing this new feature a few months ago.EXPORT IMPROVEMENTS
Those with export permissions can now export Linked Documents from the right-click context menu of an assembly. In the past you had to open the Linked Document and export from it.PROFESSIONAL IMPROVEMENTS
EXPORT FROM RELEASE CANDIDATE DIALOG
You can now export directly from the Release candidate dialog in Onshape. This is especially useful for those that need to export released data as you no longer need to load the release and browse through the Document to export.LEARNING CENTER IMPROVEMENTS
A new course, Understanding Curves, has been added to the Onshape Learning Center to explain how to create the underlying framework for advanced part creation and surface models. This course is available to Standard, Professional, Enterprise, and Educational subscriptions.
Glad to see you are still improving drawings
Effendi H.
Thank you thank you thank you thank you!
This export update seems like a first step to something more automated. I have a feeling that these things are already on the dev team's mind, and probably a lot more, but here goes anyway. I'd like to see a single click to export all released items as @fnxf_scewo suggests. We should also be able to automate and customize the naming of things there to add dates, revs, versions, custom project codes, and also to remove things like the part studio name. It would also be good to export several file types of the same item, like a .step, x_t, and .stl all at once. I sometimes send all 3 to China at once so I don't have to lose a day when they ask for the one I didn't send.
Thanks for the constant improvements. Update day is always exciting.
Website: ovyl.io
https://cad.onshape.com/FsDoc/library.html#newInstantiator-Id-map
When you are creating your instantiator, you pass it a query that filters down to the composite parts only using a query like:
https://cad.onshape.com/FsDoc/library.html#BodyType
ex.
Will take it for a test-drive in the morning.
Cheers, Owen.
Edit: make that +300 just for this release package alone...
Great to see some important improvements around release and exports but would be nice to have a bulk export button, for me, export for drawings in pdf's and dxf files from a release in one go would be a huge time saver. Please, please keep working in this area as it's currently a real productivity killer at the highest-pressure point of projects.
But yes, bulk export of anything is a high priority
Otherwise I'd likely use multi-tab again just so I could do detailing cheats where you duplicate a sheet and replace reference.
CAD Engineering Manager
