Vertical og Horisontal alignment of Diameter Dimensions
Optional alignment options for Diameter Dimensions. It would be a good option to be able to choose alignment (or direction) of the diameter options. Either along a vertical or horisontal axis. Currently the diameter dimension sits radially to a circular dimension. See image for suggested options (in red).
Please can you be more specific? I can't find this setting.
then you can add the diameter symbol in the dimension properties
@lougallo are there any updates on this?
