I need to import a dwg/dxf logo into my model and do a cut extrude. Is this possible in OS?
carlos_cruzcarlos_cruz Member Posts: 1
    Currently no, it is often asked feature so I would guess it will be implemented at some point.
    See help for more details:
    For Part Studios:
    Onshape can write Onshape Part Studios to:
    Onshape can read Part Studios from:
    • Parasolid
    • ACIS
    • STEP
    • IGES
    • SolidWorks
    • Parasolid
    • ACIS
    • STEP
    • IGES
    • CATIA v5
    • SolidWorks
    • Inventor
    • Pro/ENGINEER, Creo
    • JT
    OpenFor Assemblies:
    Onshape can write Onshape Assemblies to:
    Onshape can read Assemblies from:
    • Parasolid
    • STEP
    • Parasolid
    • ACIS
    • STEP
    • IGES
    • SolidWorks Pack and Go files
    • JT
  • r_paulr_paul Member Posts: 22 ✭✭
    @carlos_cruz
    Do you have access to a person with AutoCAD?  If you do and have the .dwg/.dxf file they will be able to open the file and export it in either acis or step formats and then you can do the rest with Onshape.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    @carlos_cruz Currently we do not import DXF/DWG in as sketches but I have added you to the improvement.
  • onshaperonshaper Member, Mentor Posts: 94 ✭✭✭
    Hey r_paul, how does this work? Just trying to get simple text onto a face!
  • james_75james_75 Member Posts: 1
    Add me as well to this improvement as well please. DXF import would make marking items easier. Logo, Part ID #, etc.
  • keppelkeppel Member Posts: 7
    please add me to the improvement.
