Improvements to Onshape - March 31st, 2020
Roy_Mutalik
Member, Onshape Employees Posts: 41
With the current situation, we hope you all are staying safe and healthy. Times may be unpredictable, but we remain focused on bringing new improvements to our users.
Let's take a look at some of the improvements in this latest release of Onshape.
The BOM will even automatically scroll if the selected part is listed lower down (or higher up) in the BOM than you have displayed on the screen.
CAD IMPROVEMENTS
ISOLATE IN PART STUDIOS
You can now use the "Isolate" feature in Part studios!BOM CROSS-HIGHLIGHT IMPROVEMENTS
You'll see improved cross-highlight capabilities in a bill of materials when selecting a part from the Instance list, or the modeling space.The BOM will even automatically scroll if the selected part is listed lower down (or higher up) in the BOM than you have displayed on the screen.
DRAWING VIEWS: PART STUDIO FILTER
With a new filter, it is now less likely that you accidentally create a drawing view of a Part Studio, when in most cases the intention is to create a view of the part.SWITCH ANGLE OF PROJECTION ON DRAWING
A new option has been introduced allowing you to quickly switch between First and Third angle projection on an existing drawing you've created. It is available in the Drawing properties, under the Views tab.
This option should be set properly when creating your drawing templates, and all views created will be of the appropriate projection. However, if it is changed after drawing creation, all projected views will automatically update based on the selection, including their names in the Sheets flyout.
PROFESSIONAL IMPROVEMENTS
OPTIONS WHEN REMOVING USERS FROM A COMPANY
When removing a user from a Company, you will now be presented with clear options allowing you to quickly revoke the user's access to all data within your organization. You can select to automatically remove them from any company-owned teams (and thereby revoke their access to any documents shared with those teams) as well as remove them from direct-shares of any documents or folders owned by the company.
RELEASE MANAGEMENT IMPROVEMENTS
CREATE RELEASE CANDIDATE FROM VERSION IN DOCUMENT
You can now create a Release candidate directly from an existing version in your current document.LEARNING CENTER IMPROVEMENTS
ADVANCED PART DESIGN SELF-PACED COURSE
A new course, Advanced Part Design, has been added to the Onshape Learning Center to help you learn advanced features such as variables and Mate connectors in part design, advanced sketching techniques, modeling with complex solid loft and sweep features, and tooling part workflows. This course is available to Standard, Professional, Enterprise, and Educational subscriptions.EXPLODED VIEWS TECHNICAL BRIEFING
A new Technical Briefing is now available, discussing tips and tricks when working with Exploded views.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
3
+1 for the Part Studio filter in the drawings view dialog
My favorite is the ability to isolate in PS
really someone requested this....
SWITCH ANGLE OF PROJECTION ON DRAWING....
The simple answer is to create proper templates. What a waste of resources by implementing this....I am clueless. Is this example of good customer service by implementing such features or bad customer service by ignoring other critical features.The Onsherpa | Reach peak Onshape productivity
This new course is excellent - Kudos to @KatieHuffman and team!
Isolate looks good, but I have to admit I was really hoping it would highlight which features on the tree were used to make the part or even truncate the tree down the relevant features.
It is far better than just ignoring the little guy.
This happened to me at least 3 times at my current job.
Where our customer changed their drawing standards from 3rd to 1st angle, then we had to go through the 100s of drawing sheets and fix everything.
Just to have them buy another (almost) duplicate system the very next year and abandoned the 1st angle projection. So we had to update the drawings back to 3rd projection during the next release (because naturally the original draft was so far out of date at that point of the revisions to be worth reusing).
in summary, Don't hate on a feature just because YOU won't use it.
I'm glad Onshape now has this option. It is pretty basic really, and doesn't add bloat.
(I voted you down by the way, because their customer service will bend over backwards and work past midnight to fix your documents, and you bash them for giving a simple quality of life improvement...congrats that is the 2nd downvote i gave on these forums)
Been waiting and hoping for the insert part studio filter since day 1. This will be a great quality of life improvement when trying to migrate people over here.
I would agree, but customers are customers...
No, they did it anyways for an even more minor issue, because that's how they are...
Here is one example of a time I caught lou working past midnight, too bad he didn't see my message until the next day...
But it was solved when I went back to work in the morning...
This is my last post on this topic, just give credit where credit is due... these people work hard to deliver a product that they care about.
(I like this because it visually looks like editing In Context, but selections are very hard to get right when working In Context)....this....just works.
Nice updates folks!
Romeo
That fulfills request: https://forum.onshape.com/discussion/12972/bom-two-or-one-and-a-half-way-interaction-with-parts-in-assembly-studio
Thank you Guys!
One thing that has bugged me, is checking the history of a document before release and seeing several dozen "hide/unhide" or workspace update type changes that don't affect geometry, making me hunt around to verify that the model geometry hasn't changed before a release. Now, I know I can create versions I'm happy with and just go back to release those as appropriate.
