Incomplete rendering of parts in assembly
edward_petrillo
Member Posts: 100 EDU
in General
While working in a fairly complex assembly, I frequently encounter a situation where several parts are rendered as "ghosts" even after the tab has finished loading. I have set the tesselation of some but not all parts to "medium' and selected "Use automatic tesselation" on some but not all subassemblies. The tesselation setting seem to make no difference whether a part is rendered completely or not. Changing the tesselation on all parts would be quite a chore- many are from linked documents. My graphics performance (462 milllion, 195 million) is the same as it as always been but the prevalence of this problem seems to have increased. The change in performance may have coincided with an upgrade to Windows 10 from Windows 7, but all of the browser settings (Chrome) conform to Onshape recommendations. The document is here:
https://cad.onshape.com/documents/68fd659f4cf18cb89d2a0243/w/3ce02e36ac8d8a5e8938c492/e/55d30a35600015f653e96719
Any suggestions for improving performance?
In general we may forego loading some parts initially to avoid exceeded the browser's memory limit. Chrome has fairly restrictive per-tab memory limits, so we will load less in Chrome in the context of larger assemblies. Firefox has a more liberal limit, so you will find that more parts are loaded immediately. So you may want to try Firefox out to see if your performance is improved. (Note: it needs to be the 64-bit variant of Firefox, which is not the standard install for Firefox.)
If you zoom in on an area, you will notice those parts take priority and begin to render in quicker.
If you want to see the whole model in full render, you will need to wait.
It isn't a limit of ram, I think it has more to do with the Onshape server re-building the un-cashed parts
