Improvements to Onshape - June 5, 2015
lougallo
Member, Moderator, Onshape Employees, Developers Posts: 2,001
Update day is here! Today we are introducing our new Part Studio compare tool as well as the ability to save Named views. A few other highly requested improvements also made the cut so let's take a look...
Highlights include:
As with every release there are always small tweaks and improvements made to increase performance and stability across the service. Big thanks goes out to all the development teams that continue to amaze us with new capabilities. We hope you find these improvements helpful and we have so many more things to share in the coming weeks/months. As always your feedback is welcome so please let us know what you think! ~Lou
Highlights include:
- NEW Part Studio compare - Compare Part Studio workspaces, versions and history right from the version and history panels! Compare shows units, feature lists, sketch and feature differences both graphically and in side by side dialogs (even which options were set for the feature).
- NEW Named view - Orient, save and restore your own custom views (In view menu)
- NEW Symmetric sketch contraint - select two like-entities and a centerline to constrain them symmetrically about it,
- Add/change emails to your Onshape account. (You must verify your new email before you can make it your primary email)
- Measurement precision has been increased as follows:
Inches = 4 decimals
mm, cm, m, ft, yd = 3 decimals
Named view is also big for me. I like the look of the interface, on first acquaintance. I will be interested to see if the functionality has been integrated with "Section view" - if not, I hope it will be in due course.
For me (because I model in mm, and 0.01mm was OK for the sort of work I can currently shift to Onshape) the measurement issue was not a drop dead one, but because I understand the inch system intimately, I'm delighted this serious issue has been addressed, for those who are stuck with working in inches.
I say thay, having had custody of top-level folders with perhaps as many as twenty sub-folders containing discrete iterations (and in a very few cases, maybe three times that many, in the case of a design which has been subjected to continuous improvement over a decade or more).
And each iteration (in Solidworks or equivalent) requires a folder-full of matching files. If a few of those get renamed or mis-filed ... I don't think I need to say more. And, of course, the older ones are vulnerable to stranding, by version change issues...
I wouldn't want to go to the extreme of a single document spanning the entire history of an assembly with so many variations, but the savings available by condensing the current starburst into a compact cluster of documents, each document spanning a handful of review iterations and releases, and potentially replacing entire folders, would be considerable.
Naturally there will have to be some serious improvements in navigability of large assemblies and complex parts, but that's reasonably routine and cosmetic, provided the concept has 'good bones'.
I get the sense that the OnS development team are (very sensibly) first nailing down the bits which have multiple effects on downstream decisions - and I can see that version comparison is one of those bits.
On that topic, it seems to me that organic growth, to the extent that it lacks a plan involving deep forethought, tends to work well in the short term, but badly in the long term. I'm talking here about a conceptual plan, and specifically about working out the optimum critical sequencing ahead of time. I'm not meaning "plan" in terms of a schedule, the sort of thing a fresh-faced MBA would obsess about.
To ask a team forging into virgin territory for a schedule seems to me a bit like asking an explorer (say, Captain Cook) to submit maps for approval before embarking on a voyage of discovery.
Edit: I would also like to see 'speed bar' for adjusting transition speed. Named views are very handy when showing model to customer but it gives better impression when movement is a bit slower to better see 'the trails' of movement. During design & setting up views faster is better since too slow would be very annoying.
I need to do some more testing before commenting other updates, sounds great though.
1) 1-click export to png (what do you mean by "link", @3dcad? - if you mean, insert the png as a new tab in the Onshape document, I like that suggestion)
If Onshape was platform specific, it would be nice if "Export to png" could open the resulting document in (say) MS Paint for adding comments etc - but given that it's not, I can see this being desirable within Onshape, for productivity reasons. It also opens up the possibility to add 2D or 3D reference dimensions which show up only in that view, which I presume is roughly what @3dcad is suggesting. This last addition is, I expect, rather burdensome.
2) A simpler addition:
When the cursor focus is on the list of named views, I would like the scroll wheel to scroll the screen display to scroll through the named views. I often use named views on large assemblies to check for clashes in key areas after design changes, and anything which speeds this up has to be good news. It would be extra cool if a given view could quickly be invoked by typing the first digit(s) of the name (I usually 'name' such views with numbers)
3) Extend saved state of Named Views to include section status (which I mentioned in a previous post), and hide/show status (which I did not)
Currently I would need this feature to grab images with some dimension and comments into printable assembly directions. But the idea of having link is for future where I imagine all assembly instructions being just on a web page that has images linked straight to live model in Onshape.
Maybe there could be a specific tab for such things in Onshape that holds multiple Named views together with animations and this way product assembly instructions could be just a link to Onshape tab.
About adding comments in external software, I would totally disagree. If you make just a slight change to model you would need to comment again or keep external (photoshop) file where comments are in another layer - this is THE pain I'm currently facing with my assembly instructions (cad + image processing + final pdf = 3 different versions).
I know this was not your point but just wanted to highlight my need to comment inside Onshape and then export to image (at this point).
Thanks for those clarifications. Makes perfect sense.
One strong ethos in Onshape, it seems to me, and a crucial point of difference with legacy MCAD, is to keep capabilities broad and shallow (aka accessible and simple), rather than narrow and deep.
I personally think @pete_yodis ' excellent suggestion would be even better if an easy way of doing it was either discovered or provided using a more general-purpose functionality (like, say, "Insert body into (another) Part studio"), implemented in such a way that the two versions arrived with the same relativity to the origin.
I'm really enjoying reading this discussion -- it very much parallels our thinking, in terms of providing relatively simple but general and orthogonal tools whose power comes from being able to combine them rather than knowing the ins-and-outs of "narrow and deep" functionality. For the boolean-then-measure case, once we do have the ability to dynamically import parts from one part studio into another (and we are working on this), that would indeed be a good workflow. And yes, we are also working on customization tools like APIs to allow users and partners to streamline workflows.
Really love the new symmetric command, another 1 ticked off my list of improvements.
https://forum.onshape.com/discussion/1039/enhancement-for-named-views
