How can i add re parts to the assembly?
Chhea_ChhavChhea_Chhav Member Posts: 3 PRO
I have two drawing and I'm trying to put it together but when i go to the assembly. i can only see one part not both.
  • lanalana Onshape Employees Posts: 727
  • Chhea_ChhavChhea_Chhav Member Posts: 3 PRO
    I'm trying to assembly my parts together and when i do, only one part show up. Not the other parts. How can i do it ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    Please share your doc URL or review the free training videos at learn.onshape.com
    You will need to insert the second part.
    Did you create the other part in a different document? or in another partstudio tab?
    If it is in a different document, you will need to click the "Other document" tab in the insert menu
    then browse to your other document. You will be prompted to create a version for the other document before you can insert the part. Accept any prompts you get.
