Creating a Partial Thread
ethan_1
Member Posts: 17 EDU
Has anyone had any luck creating a partial thread. Meaning I don't want the helix to go the entire way down the cylinder, say only and inch down. See picture attached.
nav
Member Posts: 258 ✭✭✭✭
Hi @ethan_1 as @cadmando suggest create two cylinders the second one extrude it as a new part so when you select the helix command it recognizes one of the cylinders, after finishing you can use the boolean command to convert everything into one part. (See image below)
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions5
Hope this helps, happy OS'ing
Graham
Well done with the method, I am not sure how to take a snapshot of the screen and post it to the forum, anyway I only gave the basic information, left it for @ethan to work through it alone, I learn thing better that way.
Are there instructions any ware which explains how to take snapshots and Publish to the forum, I must learn how to do this for the future.
Graham
- Press Command (⌘)-Shift-3. (whole screen) / (⌘)-Shift-4 (Part of your screen)
- Find the screenshot as a .png file on your desktop.
In windows you a can always use Print Screen and in paint crop the image some windows versions come with tools to take snapshots you can google them, or install one.To upload an image to the forum see image below:
Graham
If you plan to use the commenting features mentioned by @3dcad , it pays to save the snip first, because there is no "Undo" within the tool. If I have several edits (particularly freehanding with the mouse) and I don't want it to look amateurish, I save again after each successful addition.
This is a perplexing omission. It's not just the menu command they've omitted, Control-Z doesn't work, either. Microsoft - late to the table and forgetting the salt... sheesh!.
Graham
I have one workaround method in which no need to make two cylinder. Make helix on cyinder and perform transform operation to translate helix. Now user can use this helix to get desired partial thread.
@shanshan: I agree: this is definitely a workaround to accommodate a helix feature which is not yet fully implemented.
It is not desirable to have a curve which extends into "free" space, because it does not reflect design intent.
