Help Configuring Faces
Cache_River_MillCache_River_Mill Member Posts: 225 PRO
edited June 2020 in Community Support
Hello,
When a color is configured with a face, all of the configuration inputs are placed into columns. Is there a way to delete the unwanted configured columns? Or perhaps a way to configure a color in the standard configuration panel?
The way it is configured now, I can't configure colors unless the stars align with all of the different configured variables... Perhaps I am doing it wrong?
  • EvanReeseEvanReese Member, Mentor Posts: 2,694 PRO
    NeilCooke said:
    No, you are doing it right. Properties are config-specific so you do have to align all the stars. A wilcard option would be good.
    @Evan_Reese 's FS could be easily extended to allow face colors.
    I actually made that update a few days ago. It works with faces now.
  • Cache_River_MillCache_River_Mill Member Posts: 225 PRO
    Thank you for the quick reply. Excellent, the new updates are fantastic by the way, thank you.
    edited June 2020
    Thanks! @Evan_Reese
    This is fantastic, very well made.
    edited June 2020
    Not only can I color a part face with this, but this lets me color a face and then over ride that color by coloring the face again if the conditions require it! Wow. @Evan_Reese
    pretty cool! credit for that goes to the Onshape devs. All I did was add a line to allow faces and they made it work.
