Help Configuring Faces
Hello,
When a color is configured with a face, all of the configuration inputs are placed into columns. Is there a way to delete the unwanted configured columns? Or perhaps a way to configure a color in the standard configuration panel?
The way it is configured now, I can't configure colors unless the stars align with all of the different configured variables... Perhaps I am doing it wrong?
NeilCooke Moderator, Onshape Employees Posts: 5,863
No, you are doing it right. Properties are config-specific so you do have to align all the stars. A wilcard option would be good.
@Evan_Reese 's FS could be easily extended to allow face colors.
Senior Director, Technical Services, EMEA5 -
EvanReese Member, Mentor Posts: 2,406 ✭✭✭✭✭
NeilCooke said:No, you are doing it right. Properties are config-specific so you do have to align all the stars. A wilcard option would be good.
@Evan_Reese 's FS could be easily extended to allow face colors.1
