Hiding assembly parts when editing in context?
tony_459tony_459 Member Posts: 206 ✭✭✭
I'm editing a part in the context of an assembly, but there are many assembly parts in the way and I can't select just the one I need to select. How do I hide an assembly part when editing in context? Thanks!
    You can only hide before create or updating the context of the assembly in the assembly. Once created you can not show hide parts in the part studio.  I always try to think about this before creating but don't always get it right it.
  • tony_459tony_459 Member Posts: 206 ✭✭✭
    Thanks! That's a shame. It's very difficult to use context geometry if you can't access it. You don't run into this issue with derived parts...
    edited June 2020
    I usually transform->copy in place. All of the parts I want to reference and build of of those. Then delete the reference parts at the end. That way it makes it easier to hide/show stuff on the fly.
    If you want to add another part, turn the in-context ghost back on,edit the transform and select more parts
    This makes it so you don't need to hide your parts again in the assembly if you want to update your context.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 582 ✭✭✭
    How is it turned off? How is it turned back on? - Scotty
    Contexts will be in the top of the tree if available
  • marcus_bernsteinmarcus_bernstein Member, User Group Leader Posts: 35 EDU
    Section view usually accomplishes what I want to get at in-context, but it can be difficult to get right as we can't select faces of a context. It's easy enough to make a plane based on that geometry, but it would be nice to be able to hide particular parts from a context assembly or use a face from a context part as the basis for a section view.
    Any chance Onshape is looking for interns?
    Philadelphia User Group Leader
  • bill_danielsbill_daniels Member Posts: 278 ✭✭✭
    Suppress the unwanted parts first.
    This was reason #1 why I started transform->copy workflow. the more I didn't use that workflow the more limited it seemed, up until I just became "the way" for me.
    This one workaround (which is barely a workaround) takes care of all issues I have had ever since.
    You can even go further and derive your context (with tweaks) into another part studio or document.
    Or make your context a composite part to use in other places... etc. etc.
    It just doesn't make sense to me anymore to not have 3D part as a copy. I like working with tangible objects, The ghosting image is nice when you want to review, (but we have isolate and transparency for that)
    You don't need to suppress, just hide. Which is where display states can come in handy too, if you want to use the traditional workflows
  • nclementnclement Member Posts: 1 PRO
    Is there a feature request for this? Being able to hide parts when in context is a no brainer.
  • glen_dewsburyglen_dewsbury Member Posts: 1,041 PRO
    HMMM There seems to be a lot of optional work arounds here. Not sure why since there is s function for this, unless I'm misreading the question. Hide/show context instances. This has been working for me and is quite stable and can be updated as needed.
  • jelte_steur814jelte_steur814 Member Posts: 470 PRO
    this functionality has been added since this forum post was created. just note that it's only available when the context has been established in the document. so you actually have to use some face, line or part in a feature. not just see the context while working, because thenthis menu is not available since the context is not saved to the part studio
