Improvements to Onshape - July 31st 2020
2»
  • Theo_RTheo_R Member Posts: 82 PRO
    Some great stuff in here.
    My most valuable improvement is certainly metadata/properties oriented
    EDIT PROPERTIES OF A PART FROM AN ASSEMBLY
    Thank you!
  • soto_estévezsoto_estévez Member Posts: 1 PRO
    🎉 Updating variable names 🎉 amazing!
    So many little pain points I've had just went away. edit part properties from anywhere, center of mass, variable names (again), hide the "surfaces" folder. thanks!
    Whew... if release management wasn't confusing enough lol....
    I'm with you, John. I'm not sure what to make of this new decision I didn't know I needed to make. It's like a skydiving instructor asking what style of chute I'd like. I don't care to choose, I just want to live. Anyone care to explain the nuances?
    This comment made my day  :D
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    Nice round of updates. Especially mass properties over ride for parts that are roughed in from old vendor drawings.
    For the FeatureScript annotations, are they supported on a) enums which are set to HORIZONTAL_ENUM and b) booleans not set to OPPOSITE_DIRECTION?  In both cases I'm not able to get a tooltip when hovering over the option text, and also not when hovering over the checkbox for the boolean.  Most of those booleans are also controlling parameter display groups, not sure if that makes a difference.
    Of course, I might just be missing something. Any pointers, @ilya_baran or @MBartlett21 (despite not being an employee ;) )?
    Arul Suresh
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,059 ✭✭✭✭✭
    @lemon1324
    I have noticed it, and Lou has marked it as a bug.
    I was wanting to use it my beams feature to tell users what the difference between the manual and automatic mode of selection is.
  • tony_459tony_459 Member Posts: 206 ✭✭✭
    +1 for custom mass properties :)
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,959 PRO
    NeilCooke said:
    The time is ripe...
    ... but only if the time is right.
    But do it quick, 'cause we're so hype
    NeilCooke said:
    The time is ripe...
    So we don't have enough time to gripe...
    All the videos of this post are missing
    Un saludo,
    @Roy_Mutalik Please, could you check the videos?
    Un saludo,
    @emagdalenaC2i - fixed it - not sure what happened there.
    En este enlace podéis ver las Novedades de Onshape en español
    https://youtu.be/VnbDil1a3Wk
    Un saludo,
  • richard_marcusrichard_marcus Member Posts: 17 EDU
    Overriding the mass properties does not appear to work for a composite part. It looks like the properties are applied in the dialog, but as soon as I click the green check mark to exit the dialog, the mass is gone.
