My most valuable improvement is certainly metadata/properties oriented
EDIT PROPERTIES OF A PART FROM AN ASSEMBLY
Thank you!
Of course, I might just be missing something. Any pointers, @ilya_baran or @MBartlett21 (despite not being an employee )?
I have noticed it, and Lou has marked it as a bug.
I was wanting to use it my beams feature to tell users what the difference between the manual and automatic mode of selection is.
https://youtu.be/VnbDil1a3Wk
Overriding the mass properties does not appear to work for a composite part. It looks like the properties are applied in the dialog, but as soon as I click the green check mark to exit the dialog, the mass is gone.
