Creating a circular pattern of equal length lines in a sketch
![bit_stone](https://profiles.onshape.com/dc45ac64ba2ba0ac9f0511eceeeea06de68600cf0dbb7f7aafeb82c8bf12f174.png)
Hello there,
I am trying to create a sketch that looks like this:
![Image: https://us.v-cdn.net/5022071/uploads/editor/f6/cvyg8l15ylw5.png](https://us.v-cdn.net/5022071/uploads/editor/f6/cvyg8l15ylw5.png)
Is there a way to create those 1000mm lines without placing them all manually?
I've tried using a circular pattern.
But the radius could be pretty big (like 35000mm) and the length of the lines is usually just about 400-500mm.
Using a circular pattern I would have to convert the distance to a very small angle and that sometimes results in inaccuracies.
Any ideas? Am I missing something?
You can create a circular pattern in the sketch, then delete the angle dimension and set the ends of the lines coincident.
I*ve been testing around for a little bit.
I am currently thinking about using OnShape for our business.
This is what I am trying to accomplish:
https://cad.onshape.com/documents/4665afd6bee0c73aa715e0a0/w/8c31376fe87a14363bc91dec/e/89c48e6c954dcbf0c9e428b2
Looks like it would be best to just add the lines manually.
Is there a better way to get this result without converting the lines to equivalent angles and using a circular pattern?
https://cad.onshape.com/documents/4765de7101c0acfee316e098/w/5addae968925b8ce8149c76b/e/27406509178d4707c4fe1977
But they need to be equally distanced on every row.
But I think it would be best for me to have a look at creating a FeatureScript for this
