Creating a circular pattern of equal length lines in a sketch
bit_stonebit_stone Member Posts: 5
Hello there,
I am trying to create a sketch that looks like this:
Is there a way to create those 1000mm lines without placing them all manually?
I've tried using a circular pattern.
But the radius could be pretty big (like 35000mm) and the length of the lines is usually just about 400-500mm.
Using a circular pattern I would have to convert the distance to a very small angle and that sometimes results in inaccuracies.
Any ideas? Am I missing something?
