Stay Signed In
chase_cromwell2020
Member Posts: 2 EDU
Can we get a stay signed in feature? It's little, but it's a bit annoying having to type my credentials and sign in every time, especially when I'm the only one who uses this device.
I agree this needs to be changed. I'm able to use a password manager just fine, but it's an unnecessary few clicks every time I start my day. Gmail/Gsuite - one of the more security conscious outfits - does not make me sign in every single day. This is a totally unneeded layer of security.
The browser can remember your login too. All you need to do is click the sign in button.
By comparison, I don't even notice the Onshape log in.
You encourage users to save their credentials in the browser, so what is the point of log them out after a few minutes? Especially when this happens during working on a sketch - it's one of the most annoying "features" in Onshape.
https://greasyfork.org/en/scripts/565664-onshape-auto-login
If it happens when you're working then it's likely your network keeps dropping out. Onshape (or rather, websockets) require a stable connection.
Then make authentication set a secure http-only cookie that is read by an endpoint responsible for generating whatever bearer token the websocket connection requires. When loading the client, try the endpoint to find out if the cookie exists and works. If the endpoint fails to return the websocket token, ask the user to log in.
