I have added you to the team as it appears that you have too much time to hang on forums..
In a sea of madness talking to like-minded folks on this forum a couple of times a day keeps me sane.
Cheers,
The parts I did are out of sheet metal (since I am a sheet metal guy)
I would create the front fender using a bump bend technique at the press brake. (flat laser cut)
Instead of using tube for the main portion of the swing arm I constructed it out of 3 parts that would be laser cut and bent at the press brake to create the tube look. (did this on a previous project).
https://cad.onshape.com/documents/86337c4030f19db4931f9303/w/be7bf019ed4dcda086517304/e/279f6a6f34a13f92255660ad
Twitter: @BryanLAGdesign
To go with the tires, front fender,and swing arm I drew in Onshape I found a front supension desinged by Robert Giguere and a rear shock designed by Edward Fenton.
My next big search is for an electric motor and battery. If there is a public one let me know.
I am with you on wanting to use this project to learn and leverage Onshape's collaboration tools. I am also a team of one.
If we could get enough interest and participation for this project it might work. I think to start would be to agree on a master sketch and then divide and conquer sub assemblies.
Our current user group meetings have been virtual so some of us have experience meeting at designated dates and times on Zoom.
It's been up and down in Lafayette. We started the year of great but then Covid hit and it's been a roller coaster ride. Currently for us our cutting (laser, water jet, and plasma) and press brake bending work is up but the fabrication side is down.
@matthew_stacy where are you currently residing and how are things on your end?
- document sharing
- branching/merging/versioning
- commenting features
- screen follow
- ... and numerous others that we may not even know about yet.
I started the crudest of models for a scissor jack (Northern Tool & Equipment, Item# 46212). Anyone that would care to join this exercise is more than welcome. I need your email address to assign document sharing privileges.I feel that I need to do something so that my skills in CAD in general degrade. I don't have musch experience with motorcycles but home that I can contribute in some way.
https://grabcad.com/library/2018-surron-light-bee-1
What do you think @matthew_stacyTwitter: @BryanLAGdesign
https://cad.onshape.com/documents/57e1def9ae11fc114fba0e28/w/c3d84717e546adb84412834d/e/7c7131cbe87ece1740ebff21
https://cad.onshape.com/documents/57e1def9ae11fc114fba0e28/w/fa0b8ce2454bfa01e965c528/e/f7634fd40208fec4754cfcc5
By the way everyone is welcome to join in. Just message me your e-mail address.
A little bit about myself, I got a mechanical engineering diploma and currently working on my bachelor's degree. I got some experience in electric bicycles, the super mileage car, and I am a big motorbike fan (mostly japstyle bobber and cafe racer), and heaps of experience using 3d modeling software and FEM FEA software as Inventor, Solidworks, Fusion, and ANSYS. I hope I can help and learn something from this project !!
But I got a few questions for this projects:
- Are we still on the concept design, or are we in the process of determining which type of motor and controller to use?
- What are the guidelines of this project, do you guys prefer to use standard items with standard dimensions on the market, or can we design something totally new?
- What is the desirable top speed, battery capacity, acceleration, torque? I have seen on the first page that the desired power is 100 kW and 100 Nm torque, is that still the scope?
- What is the workflow here, do we have to do everything on onshape, or can I import some parts that I made from different software??
RENDERCAD
