How can I set the sweep path to stop at a certain face of another part in a project?
largo_cba
Member Posts: 5 EDU
I guess a picture works better than an explanation:
All I want to do is to make the part that is diagonal to "stop" or be cut right at the edge of the other two pieces.
How can I do that?
https://cad.onshape.com/documents/7ecba141d2e4171944be3a63/w/989812626d22ff384c60a6d5/e/d72d23a852ae860dde922fc9
Here's it if you want to take a look.
All I want to know if there's a way to make it look like this:
Please do note:
The "metal" legs are all hollow, I think I made a mistake making them hollow first but I didn't know how to make them hollow afterwards.
EvanReese
Member, Mentor Posts: 2,756 PRO
I'd do the sweep as you've already done it, then use the Replace Face command to edit the end to match what you want to match. However, for the kind of work it looks like you're doing, check out the awesome Beam custom feature by @NeilCooke
5
How do you use the beams script? Is there a tutorial or something? I don't know how to make the script be available in my project.
Thanks
if you click the "+ Custom Features" button you can pick "Beam Feature", then it will be added to your list of custom features at the right side of your feature menu. There are a ton of good custom features out there. Get started exploring by clicking the "learn about featurescript" button at the bottom of the "add custom features" window.
https://cad.onshape.com/documents/ecc8d10f39fa36bfe732e601/w/927b2888722ef93e0fa728e0/e/be557310068a83699a976a0a
