HOW TO CONVERT SURFACE TO SHEET METAL?
baldo_flores
Member Posts: 5 ✭✭
Does any one know how to convert a surface to sheet metal?
john_mcclary
Member, Developers Posts: 4,065 PRO
In whe sheetmetal feature choose the thicken option0 -
MBartlett21
Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
Alternatively, the Convert option can be used if you want to use all faces of the surface.
The only surfaces supported are cylindrical, extruded, or planar.0
hey
what to do if I need to get a unfolder from a surface (single curvature)
the point is for my case the surface is not cylindrical or extruded, it is loft and single curvature and I need to get a unfolder
Then check out this resent custom feature from Konstantin
