Improvements to Onshape - June 26, 2015
lougallo
                    Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
                    Who is ready for update day?  I am excited to announce a number of improvements across various areas of Onshape today. Little improvements like arrow key navigation on the Documents page to some larger updates like 2nd end position extrude span the list so let's get to it:
Highlights include:
Part Studios:
                Highlights include:
Part Studios:
- NEW 2nd end position Extrude -  A new option in Extrude introduces a second end position (double arrow) that can have it's own set of end conditions and supports direction control.  This allows an offset sketch situation to be controlled easily.
 - NEW Feature List filter - At the top of the Feature List you can now search by name or type.  This will display the list in a filtered view and collapse sections that do not match the search.  Pro Tip:  Hover over the ellipsis '...' to see the features collapsed in a tooltip and rollback also works!!.
 - NEW Copy/Paste Sketches - Now you can select and copy sketches to use in the same Part Studio or another Part Studio in another document.
 - NEW Silhouette tool - When in the Use command there are highlights that allow you to convert the silhouette edges of your choice.
- Hide/Show using Groups - A new option is now available for Assemblies that use Groups.  The Group can act as a quick selection list to change the visibility state (hide or show).
 - Reset mate positions in sub-assemblies from the top level assembly - In an Assembly, access to the reset option is now available on any mates created in a sub-assembly.
 - Assembly selection boxes show same name/color as the Part List - In instances where the mates fail to solve (displayed in red) or are suppressed, they will now display with the same color and name that are displayed in the Instances list.
Before:
After:
- Arrow key navigation on the Documents page. (The Delete key also works!)
 - Rename and copy workspaces from the Documents page using the gear menu.
 - Version selection on Parasolid export.
 - Zoom to selection in the view cube (shown only with an active selection)
 - View cube corners on all corners - Clicking on the corners will show the corresponding trimetric view.
Regards
Linked[in]
Great work OS Team, will enjoy learning these new features in the next few days, looking forward to the new features to arrive in existing documents as a couple of them will be very useful
Thanks OS team (Brill).
I say this because 2nd direction for extrude is an example of something that all MCAD packages offer, making it predictable and inevitable that Onshape would do so sooner rather than later (especially given Onshape already had implemented that ability for Rotate).
Setting up isometric views for the other seven options, in other packages, has been a laborious exercise, and now that Onshape has named views, this speedup is a real bonus. (Often the default single isometric does not show key features of the part or assembly)
Note #: @lougallo : re <<View cube corners on all corners - Clicking on the corners will show the corresponding trimetric view>>
Do you really mean trimetric? Surely these default cornerwise views should be isometric?
This is known as "derived sketch" in Solidworks, and means that design intent can be respected, into the indefinite future, when the original sketch is resized or even reconfigured.
suggests that the intention was for the bubbles to deliver isometric views. I would strongly argue that this is a better option.
For one thing: if "Up" remains up, there is only one isometric view possible at any corner, hence only eight possible solutions.
Whereas there are multiple possible trimetric views at each corner, so Onshape is currently making a decision on behalf of the user by privileging one.
If there is a constituency for trimetric views, maybe there could instead be a "trimetric" button which (once a given isometric view was shown) would toggle successively through the trimetric options from that same corner. (Same for dimetric, perhaps)
