revolute mates
robert_stiles
Member Posts: 156 PRO
Mates and assemblies question please!
Is it possible to limit the revolute mate by anything other than numerical input on the angle? i.e. limit to a plane angle (in the model) ? or better still, limit between hitting this object, and hitting that object?
Also, If I have 2 hinges? when I start to add a 2nd revolute mate to the other hinge, it is not so good. sometimes it locks it, especially if I put limits on one of the revolute mates? Other questions in the forum seem to suggest using the revolute on only one, and locking the position of the other to the moving part with other kinds of mate. Is this the best work flow?
Thanks so much
Thanks so much
From there you can set min/max values
Or better still, limiting it between part interference? i.e. its limited when this part hits that part??
Also, Thanks @NeilCooke - I think this makes sense to me.
limits are for when you want to be able to drag and move parts to see the part move through the whole length
suppressing mates between configs will make the part snap to each position.
