Improvements to Onshape - January 25th, 2021
Lindsay_Early
Member, Onshape Employees, Developers Posts: 26
I hope everyone has had a great start to the new year. We are excited to bring you our second release this month. This release brings big improvements to the Loft feature and more. Let’s take a look!
GENERAL IMPROVEMENTS
LOFT IMPROVEMENTS
Loft has some big improvements to give you more control and create more predictable shapes.
FILTER IN ASSEMBLY
You can filter an Assembly tree with a search at the top.CONFIGURED REFERENCES
When opening a reference using the right-click option to “Open link document” or “Switch to <component name>”, the opened element changes to the same configuration as the reference.
REMOVE FROM MULTIPLE SHARES AT ONCE
You can remove yourself from the share for multiple documents at once. This is especially helpful for EDU environments where teachers may need to remove themselves from multiple student shares.
MOBILE IMPROVEMENTS
IOS RENAME EVERYWHERE
You can decide if a variable rename should update all references.
IOS CUSTOM RESOLUTION EXPORT
You can export OBJ, STL, and GLTF files with a custom resolution.
FILTER IN ASSEMBLY
This is great. Does it mean folders are coming to assemblies?Thank you Onshape team! I will definitely be using this.
RENDERCAD
Effendi H.
Much appreciated
Loft improvements are awesome
Yea, probably the wrong meme, but It was most of images on google, I'm at work can't waste too much time looking at images..
I'm curious if we need Assembly folders now that filters are working - Folders are kind of just a way to focus or filter a list of things (think Folders in Outlook - same as tags in Gmail). I have a feeling that getting good with filters might help with 90% of the use cases that people needed when asking about folders (make the Instance list shorter, show mates only, show fasteners only (wait is that one of the filter types?)) etc.
Happy about the lofts too.
For instance, a folder for:
made parts
purchased parts
fasteners
reference parts
(all of which are either: Parts/assemblies/both)
this is the default structure of all of my solidworks assemblies.
Inside fasteners I sometimes sub divide into fastener type HHCS, FHCS, etc to make it easier to find/modify a bolt type in the entire assembly. When the assembly starts getting very large and you can't simply look at the model and find the m4 flat head screw at a glance
These also help visualize the BOM structure to make sure your BOM is sorted correctly.
Tools, Options ........ To be able to set personal preferences
Assembly folders ..... we have been waiting so long for this
Previous view ...... Should be simple to implement.
Multiple insertion ......... If I have 20 holes in a drawing, I have to put in 20 center marks.
Why is "Flat Pattern" not in view orientation when inserting a view in drawings
Is there a way to slow down the commentary on these videos, or, could the commentary be a little slower please?
Here you can see the 1.125 improvements video in Spanish
1) that's the problem I'd rather have, so no gripe!
2) no problem hearing; it's more tracking and recognizing which are the significant details happening on screen that I had to go back for. e.g. "rectangular" vs "full round" was kinda subtle to catch at speed.
Lofts and assembly filtering (esp. for errors) look like big utility wins. Yay Onshape.
